It is currently Sun Aug 24, 2025 4:25 am
PostPosted: Thu Oct 10, 2013 4:13 pm
First name: Tom
Last Name: West
State: Nova Scotia
Part of yesterday was spent bending sides for a couple of guitars. As I was setting up and marking, posts of folks bending two left or two right sides came to mind. Of course yours truly never stumbled into that trap........................liar, liar, pants on fire. Maybe, a long time ago.
When preparing for bending I use a cabinet makers triangle on matching ends of the sides. Lay the sides end for end with the show faces up. Most times this is the mating faces that were cut apart during resawing. Make sure the mating ends abut each other. Mark these ends so it shows on the show face. Chalk works for me.
When setting up on your form make sure the mark is up and on the same end of the form for both bends. Voila, a right and left side. Hope it keeps someone out of trouble.
Tom
PostPosted: Thu Oct 10, 2013 5:31 pm
First name: Trevor
Last Name: Gore
City: Sydney
I've always used a double width side bender, bending both sides at the same time. Joint the top edge of the sides, place together book matched, bend. Pretty hard to get wrong... Only one cooling off period, too.
If you have a single width bender, set up the same way (jointed edge to jointed edge), show side facing you and write "up" or some other equally insightful comment or mark on each piece of what you're looking at.
http://www.goreguitars.com.au
PostPosted: Thu Oct 10, 2013 6:05 pm
Open the book, draw some lines across the top with something that you can see. Make sure those lines are always facing up when you bend. IProfile before bending so the narrow side is always forward.
PostPosted: Thu Oct 10, 2013 10:56 pm
Last Name: Gleason
City: Kurtistown
State: Hawaii
Zip/Postal Code: 96760
Todd, I've bend many hundreds of sets of sides over the last 40 years, and unfortunately bent more than a few of them backwards using the lines and arrows on the wood method. The lines and arrows method is aggravated by the fact that I roll my sides in paper before bending, so the transfer process gets a little spacey sometimes.Your blue tape idea is excellent. Thanks for a very simple solution to unwanted accidents. Enjoy your building!
“ The meaning of life is to find your gift and the purpose of life is to give it away” Pablo Picasso
PostPosted: Fri Oct 11, 2013 11:24 am
First name: Tim
Last Name: Lynch
City: Santa Cruz
Zip/Postal Code: 95060
"This side up"
Neck ->
PostPosted: Fri Oct 11, 2013 1:39 pm
First name: Kevin
Last Name: Quine
City: Hudson
State: MA
Country: Usa
Yep...I always mark the ends on the show face. Butt or Neck. Just be careful with pencils though....its amazing how deep a dent a sharp pencil can make on some woods. I use chalk or tape now. Nothing worse than a linear crease from a pencil line in the waist area that shows up when you apply finish
PostPosted: Fri Oct 11, 2013 2:08 pm
Nothing worse? ;)
PostPosted: Sun Oct 13, 2013 4:57 pm
make it simple
you have a flat side for the top. so do one left then one right. Also a chalk mark on the tail end when placed across the 2 sides all you have to do is check to see your chalk
PostPosted: Sun Oct 13, 2013 5:44 pm
First name: duh
Last Name: Padma
Big bite on the neck joint. Me can tell me teeth marks well enough...thats if me forget to knock off a small corner for indexing immediately after ripping them up.
PostPosted: Mon Oct 14, 2013 10:55 am
First name: David
Last Name: Eddy
City: Mandeville
State: La
Zip/Postal Code: 70448
This post had perfect timing! I'm about to bend some sides!
PostPosted: Tue Oct 15, 2013 7:35 am
Last Name: Arnold
City: Newport
Zip/Postal Code: 37821
I draw a line straight across the sides at the waist, on the inside. I bend by hand on a pipe, and I start at the waist.....with the line visible on top.
PostPosted: Tue Oct 15, 2013 9:08 am
First name: David
Last Name: LaPlante
I do precisely as John describes above, my line is in yellow pencil the position of which I determine by laying a piece of masking tape along my masonite bending template, trimming the ends and marking the waist then removing it, laying it down on the side and marking accordingly.
The reverse of the sides are marked "out" with arrows indicating "up" (top) as well as "neck" and "Butt".
I too bend the waist first, then upper bout, then lower bout.
